Question about Panasonic KX-T7730 Corded Phone
How do you program a Panasonic KX-T7730?
I am wanting to update all of our extensions, but I am unable to do this, could you please help me
Thanks
Betty
  • Carl Navarro
    Carl Navarro May 11, 2010
    You don't :-) You use a 7730 from the first extension to program the SYSTEM. Since each system is different, try to get the model number on the cabinet in the "back room".
  • 113 Answers
I assume that you want to program the extension names.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
Posted on Mar 24, 2010
  • angy_bakker Sep 09, 2011
    hi - great answer but the part i am stuck on is entering the name just like texting..... only number come up, my instructions say To enter Mike
    - Press 6 then press the SELECT button once to enter M
    - Press 4 then press the SELECT button 6 times to enter i
    - Press 5 then press the SELECT button 4 times to enter k
    - Press 3 then press the SELECT button 4 times to enter e
    I can't find the 'slect' button!
  • Baha Uddin Aug 26, 2012
    great answer
SOURCE:
Panasonic kx-t7730
What are you using to program.
PT Programming or you are using a PC Tool?
Did you save after setting names?
Jan 02, 2014 | Panasonic BTS Panasonic KX-T7730 White...
How do I update the time on the panasonic kx-t7730
that is not pssible to set from telephone
there is a PABX device (panasonic kx-tes824 ) fixed in wall
from that PABX check 101 extension number (maybe 10, wich phone connected jack1 )
from there is only you can program
Please let me know this useful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
Names
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
Thank you.
Jul 17, 2009 | Panasonic KX-T7730 Corded Phone
Change Extension No's
You have to go to your phone switch, I believe that all Panasonics are modular connectors. Look for a label that will correspond to your extension number. Find your other extension and then unplug and plug.
Cheers.
May 13, 2009 | Panasonic KX-T7730 Corded Phone
In the company to dial my colleague's ext. number(11)
Find a spare button on the left side of the phone and press PROGRAM, the button, and dial 1 plus her extension STORE.
Now the button becomes her DSS (Direct station select) and busy lamp,.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
Lost panasonic KXT-7730 password
If you lost the password the only way to get into programming mode is to reset the telephone system to factory default. If you are not accustomed to all programming features this is not recomended because resetting will whipe out all programming including ringer settings, extension names, speeddials, routing and class of service. If you still want to reset let me know.
Dec 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic Adv Hybride System KX-T7730
Thank you.
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
Program manual
Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
Jul 17, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
2,291 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
