If your friend has the exact same model computer, you should be able to use the drivers to install onto your computer. As for recreating a recovery disk, that is a little more complicated, for legal reasons. The operating system on your laptop has a unique serial number, as does your friends. That being said, you can't install the same operating system from her laptop, onto yours... as that serial number is already in use on her computer. Your best bet is to try to use her drivers, once you've installed an operating system onto your laptop.
my operating system is XP (SP2). But I have a serious problem on installing XP. After I formatted my laptop and create 2 partitions on it, I tried to install XP on first partition. my laptop copied the needed system files and set up utilities, it started setup but after a while, it gave an error that set up can not continue. the message contains such sentences: "check bios update bla bla.. " and "change video port (or something like that).. " what should I do?
hmmm, actually to be faster, I formatted the entire space in quick format mode.. I will try it in 15 minutes..
whats the operating system your using
