Question about Refrigerators
Frigidaire professional refrigerator
My fridgidaire pro series side by side, model plhs269zdb4, simultaneoously dispenses water at the door when the water paddle is depressed AND into the ice maker from the water flow tube. Causes way too much water inthe maker. As long as the water paddle at the door is engaged, the water flows into the ice maker and at the door.
  • Peter J Williams
    Peter J Williams Dec 28, 2013
    I replaced the triple solenoid water valve... still malfunctions. It continues to dispense water into the maker and at the door whenever the water paddle is depressed. Continues to overflow the maker. Wiring and water hoses are correct.
  • MrFixit
    MrFixit Dec 29, 2013
    Did the triple solenoid come with a new harness? If it didn't. There is a small diode on the harness for the triple solenoid. The diode prevents the current from going to ice maker fill solenoid and the water dispensor solenoid at the same time. The main valve solenoid will activate regardless of which one is calling for water.
    Habit-Forming:
    New Friend:
  • 21 Answers
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Posted on Dec 28, 2013
  • MrFixit
SOURCE:
  • 52 Answers
SOURCE: Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
SOURCE: water dispenser not working
how do you replace the filter? JerilynnC
Posted on Feb 23, 2009
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
I have a Fridgidaire Front load Gallery Series Washer, Even when the machine is off the water is still comming into the barrell and the cycles aren't working right. help????
Hi bingoqueen12 - Often when a unit continues to fill with water, it is because the water valve or sensor is faulty or the control board is experiencing a communication problem. The unit may possibly think that there is not enough water inside and/or the control board is not controlling the water valve correctly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Mar 16, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a fridgidaire refrige and water keeps pooling in the bottom of the refrige and then leaking out the bottom when it fills.....what is the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hi, i noticed water coming from the back of my fridgidaire fridge model ftr81sgh
sounds like a frozen water inlet to ice maker . needs too be defrosted and may need a water valve as it may not be shutting of completly .mm
Aug 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridgidaire Electrolux Professional Series Oven, not preheating
The model number listed in your problem is a refrigerator.  Go to:
http://www.frigidaire.com/manuals.aspx
and enter the model number of your range/oven unit to find the user manual.
On my GE range I only have to press and hold the LOCK button for several seconds (until it beeps) to unlock it.
May 28, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice smells, and tastes bad...no filter to change?
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
May 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Compressor is running, but not cooling.
there some thing is wrong check your service manual
Apr 07, 2009 | Frigidaire Gallery Series GLHS68EEQ 36" 26...
Fridgidaire Gallery Series Dishwasher Leaks from bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wre
Mar 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
I have water in the dispenser but the ice maker doesn't fill
replace the solelnoid for the water dispenser in the back of the fridge
Oct 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
