I did some digging and came up with a possible solution. I plugged the iPod into my PC, brought up Device Manager, went to Disk Management, then looked for the iPod capacity in the list. I went through the stages of formatting it with Windows then I restarted the restore from iTunes. I was successful in being able to restore the iPod and getting the latest update installed. Hope this helps.
SOURCE: charging my IPod
first thing its getting charge through pc'c usb> it will get charged through teh dongle>so connect the dongle to teh pc make sure pc is up and rounning and connect the i-pod and that will charged initially u can see the light orange blinking which means its charging and u can either turn on it or off it while charging thx rate me solved if its helps
SOURCE: can't upload songs on my ipod
i have the same problem. i tried everything but nothing worked .. sorry
SOURCE: I Pod shuffle (2nd. generation) won't hold a charge
Hold in the play button for 10 seconds to reset. If that fails:
iPod shuffle Software Update and Restore
Apple periodically updates iPod shuffle software to improve performance or add
features. It is recommended that you update your iPod shuffle to use the latest
software.
You can choose either to update or to restore the iPod shuffle software.
• If you choose to update, the software is updated, but your settings and songs are not
affected.
• If you choose to restore, all songs and data are erased from your iPod shuffle. All
iPod shuffle settings are restored to their original state.
To update or restore iPod shuffle with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software install file and follow the onscreen instructions to install the
iPod shuffle Update.
3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod shuffle software.
If you use the iPod Updater application and it doesn’t see that iPod shuffle is
connected to your computer, turn iPod shuffle off and turn it on again.
SOURCE: Ipod shuffle (2nd gen) completely dead
you are still under warranty...take it to the sony apple store...they will fix it /replace it or tell you there is cost if it not the battery (note do not tell them you charged overnight, and for the future do chage any gadgets more than 3-4 hrs) when you do charge over night you are actually shorten the battery life span or overcharge....so as soon as you come home from school,work,whatever cell/ipod or any other device needs to be charge...charge it now and unplug before you go to bed....
SOURCE: my ipod shuffle 2nd generation won't turn on and I
http://www.apple.com/support/ipod/five_rs/
If this doesn't fix it, and it's over a year old, and you don't have an AppleCare Protection Plan... Recycle it, because man, it's gone.
BTW: The unit charges off of a standard USB port. Double check the connection and USB cable for defects and try another computer and USB cable.
-=/ MLF /=-
