I HAVE A FRIGIDAIRE FRONT LOADING WASHING MACHINE, MODEL #GLTF1040A50. TYPICALLY THE CLOTHES ARE JUST DAMP WHEN I TAKE THEM OUT OF THE WASHING MACHINE, BUT NOW THE CLOTHES ARE VERY WET. THE MACHINE IS NOT SPINNING THE CLOTHES OR DRAINING THE WATER LIKE IT USED TO. DO I NEED A NEW PUMP?
The pump is probably obstructed by an object. Typicial it will be a coin. You will need to gain access to the pump, which should be located on the bottom front to the machine. Remove the hoses to the pump.(Important..have a bowl or pan to catch the water that will come out of the hoses)
Turn the machine on a cycle that will turn the pump on. This will let you know if the pump is working correctly. If something is in the pump,remove the pump and remove any obstructions. Then just reverse the process to reassemble your machine. If the pump is not working thaen you will need to replace it.
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
