SOURCE: I could not install PrintMaster Publishing Suite
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
SOURCE: Have Windows 7 Home Premium (64-bit)on a new HP
(make your program/application run with windows 7)
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
SOURCE: I have used PrintMaster 10
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
Testimonial: "Thanks for your help. I will investigate purchasing Printmaster 18.1."
