Disney Lightning McQueen TV Logo
A
Anonymous Posted on Dec 27, 2013
Need to program the remote for lightning tv/dvd
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
2helpful
2answers
How do i program my tv too play dvd player
The TV remote should have a source button on it, you need to press it and find the scart socket or hdmi connection, it should display a list of the connection that are use for your TV. Some times you can use the power on on the DVD, so have your TV on then switch on the DVD and this may change the TV to the input that you have the DVD connected to automatic-lay. If you are using a TV arial for the DVD to connect to the TV then you need to tune the TV to the channel the TV is using I think in most cases it is channel 21 on the TV.
3helpful
Memorex Dvd Remote Codes
Hello
Setup codes for Memorex DVD with Direct TV [TC RC32] universal remote are>
20695, 20831, 21270
OK.
1helpful
We had a lightning strike which hit the house phone wire and knocked it out. the tv and dvd player didn't get hit. we turn the dvd player on it plays but no picture. the input button on remote won't switch...
Check the TV internal fuse. If fuse is OK check the SMPS. Lightning damage could harm any part and step by step only it can be found.
If you have insurance for your TV and other appliances, you can claim.
Better contact the authorised service provider for assitance.
Need codes for Go.Video remote control
Go video remote for dvd/vcr recorder combo; you program TV by 2 digit codes. press TV power down when TV is powered on; and input 11 for JVC TV, or 03 for GE TV. You can experiment any two digit codes until TV shut down, then you have just finished programing n150b remote. This also work for all LG dvd/vcr combo recorder remote such as 6711RN203A..
2answers
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
2helpful
5answers
Lightning Mcqueen TV/DVD COMBO
my lightning maqueen tv dvd player keeps cutin off what do i do
25helpful
2answers
Need instruction to program the remote RCA 450
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
