I looked the replacement bulb and they look identical. I would like to know if the epson maviemate 72's bulb could be placed in a moviemate 50/55. Thanks for any help. It will be galdly appreciated.
Hi I am Vortash .. I have just downloaded both manuals for these projectors from http://www.safemanuals.com and they look by all intensive purposes the same the part number is however one digit different ...on the 50 it is ELPL44/V13H010L44..on the 75 it is .
V13H010L43 .. so as you can see almost the same but different .. look in the manual and check the luminance and the specs if they are the same I should think the only difference is the carriage .. but it will be down to you to try it other than that give Epson a ring ask for support and I am sure they will help you ... Regards Vortash
Thanks alot for your info it was very helpful. The reason why I wanted to know is because the cartridges look identical but the bulb is more bright and its an HD bulb in the 72. I was wondering if I put an HD bulb in my Epson 55. Will it be HD and have better quality picture. I believe that the only difference in these units except for the swivel and a few minor features is the HD bulb that they use in the 72. thanks again.
