I cannot get the soundbar to produce sound, it is hooked up as directed from Sony, it indicates tv must be arc ready, no idea if tv is or not, nothing provides this information. I have not hooked up the optical cable, as it will not fit in any of the outlets. Is there a specific hmdi outlet to use, none seem to be labeled as diagram indcates?
Arc ready is when there is electricity plugged into the TV,There is only one HDMI cable and that is the one you have. Cause all new TV's come with these cables.If you are using Av cables for the sound it will not work ,you must only use HDMI cable's.Cause some or most new TV's with HDMI dont like to use Av cables with HDMI,so if you havw something else that uses Av cables plug it out and sound will work.
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
