Can you please help with error F57?
SOURCE: bosch washing machine error code
I've had the same problem, when we had a power cut I opened the door and after that I could only got F21 flashing! ,I googled for the answer and this WORKED:
Turn programme switch to 6 o clock,hold RPM button turn switch to spin, release RPM button
SOURCE: error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
SOURCE: I have an error code
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to
drain the water, from the pump then unscrew the large drain cover and remove the
blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II
in the top and setting the machine to 'drain'. it should beging to drain
Model of machine is Logixx 8 VarioPerfect
Thank you for your reply. We had contacted a technician and he thinks it might be a fatal error where the brushes need replacing. Our washing machine is about 5 years old and we already had the brushes replaced once.
