FUJIFILM FinePix S2950 / S2990 Digital Camera Logo
A
Anonymous Posted on Dec 27, 2013
Date stamp on fuji finepix s2950
How do I / where is the setting to date stamp the photo?
3 Related Answers
Anonymous
  • Posted on Aug 06, 2010
SOURCE: Date and time stamp
I wish to have this issue solved too!
It is very useful to have timestamp optional as in most other cameras...
E.Sarris
Anonymous
  • 1940 Answers
  • Posted on Apr 15, 2011
SOURCE: Need to activate date/time stamp
In playback mode, press DISP/BACK to select a playback display format. This will turn the Information display on, which will show you the date/time the picture was taken.
This camera does not have a Time/Date Stamp that actually stays on the picture like some cameras do. Instead, the Time/Date Stamp is included in the Image File Properties, and can be viewed or modified from any Windows PC.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Testimonial: "excellent answer. Had I known that the time/date stamp could not be displayed on the picture, I would never have purchased the camera."
Anonymous
  • 78 Answers
  • Posted on May 04, 2011
SOURCE: how do i date stamp photos from a fiji finepix
This is the manual for your camera it will tell you everything you need to know about it :)
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/xp/finepix_xp10_manual_01.pdf
Date stamp on pictures fuji camera
Your camera stores date in the JPG file. Try this software to automatically add stamps to photos: TimeToPhoto
Time/date stamp for fuji finepix 70z
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
2helpful
Fuji finepix z time/date stamp photos
Can this camera do date stamping?
Date Stamp on the uploaded picture
The date and time (and a lot more) are always stored with each picture in its EXIF metadata. Just about any photo editor/viewer should be able to show you this data.If you want the date stamp printed, please consult the documentation for whatever program you're using to print. Depending on the program and printer, you can print the date stamp on the image, in the margins, or on the back.
How to print date on photo - finepix s5600
Go into the settings of the camera and look for anything called "Date/Time Stamp." Enable this setting and the date will be printed on every picture. Be careful, though. Date/Time Stamps are not easily removed so make sure you want it on whatever you are photographing.
Hope this helps.
Date and time stamp
E.Sarris
How to print date stamp on photos
Navigate the menus in the camera. One of them gives you the option to use the time/date stamp or not. Remember, each different menu section gives you multiple areas that you can adjust and change settings.
1helpful
Date & Time Stamp
The date is printed on the photos using the "pict bridge" software. The date printing option is set on the computer, not the camera. If the printer has it disabled or it is a printer that doesn't support it, you won't get the date.
How do you print time/date stamp on photos?
okay you have to hold the "F" mode menu then go to the printorder (DPOF) and it'll say with date or without date
Top FUJIFILM Cameras Experts
ZJ Limited
ZJ Limited
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
