My Cuisinart ss-700 is leaking clean water from underneath the machine. It starts after the brew cycle but long enough after that I never catch it in the act.
SOURCE: My Cuisinart Grind and Brew has begun leaking
I also have the same problem with water leaking out of the bottom.There is a defective hose underneat the burner plate (dry rotted)Mine is manufactured in 05.We contaced Cuisenart to make them aware of the problem and they told us nothing they could do it was out of warranty.After talking to 3 of there costumer service reps.my husband decided to take it apart and found the shredded hose leaking water on the electrical wires.That is why we contacted the CEO of the company and The Consumer product safety commision..They are handeling this issue.You can contact them also .
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
SOURCE: Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Mine is brand new. We are on day two of using it. Could it have been defective to begin with?
put teflon tape in thread on pipe , if it is factory instalation replace machine under waranty.
