Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Logo
r
robert orabone Posted on Dec 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not connect to internet with my stealthg2 eventhough wifi strength strong
I cannot connect to the internet eventhough my wifi signal is strong. all it says connecting, but is isn"t
buda2832
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Dec 28, 2013
buda2832
Expert
Level 2:
New Friend:
Answers
59
Questions
Helped
22658
Points
156
Check to see if it's doing MAC filtering(turned on) if so you need to add your mac address for the device
Amazon Fire box keeps freezing during shows, especially at night. Please help!
I have seen this happen with my firebox, I contacted Amazon and they sent me a knew one. They will have you troubleshoot first. Usually they want to make sure the firmware is updated and that you have a strong internet connection. Sometimes the strength of the WiFi signal causes issues.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
2helpful
My tablet will not connect to my internet
Can't connect to Internet through WiFi on Android Tablet/Phone. ... 4.Try to turn off/on Wi-Fi on the device. Turn off Wi-Fi first, [Settings]>>[Wi-Fi] >>[OFF]. Then turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[ON].
Can't connect to Internet through WiFi on Android Tablet/Phone - Asus
www.asus.com/UK/support/FAQ/1003867 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=tablet%20will%20not%20connect%20to%20my%20internet
I can't get get my Google account to go threw keeps connection isn't strong enough which I have max strength wifi?
can you log into your wi fi router admin account ?
Can you try changing the channel from auto to say 3 channel numbers higher than the lowest channel number available . This is in case you have neighbors with wi fi that might be interfering with your wi fi signal .
1helpful
Tried to connect with optimum wifi . message says authorization problem. signal strength says strong
Unfortunately for you you're going to need the login and password in order to get into that wifi. If you don't know what that is then try another wifi access point in the list. All wifi is not created equal even though it has a strong signal it still may require you to have the security key which for most of us is just called a password in order to get into the wifi access point. Good luck
I already asked the question and then had to get off the computer. The question was how do I stay on the WiFi internet through netgear router. When the WiFi symbol shows I am conneted if I go too Chro
Need to know your signal strength and if you're connected with proper credentials. If the wifi signal is weak, the computer may disconnect to look for a stronger signal. Sometimes ipv6 is the culprit on older computers too. Disable that and use ipv4 only. There are multiple reasons for dropped internet so the more info about your system and the conditions under which the internet is dropped will help in diagnosing the problem without sending you on a wild goose chase.
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
I have strong wifi strength but no connection
It sounds like you're in range of a wifi signal, but haven't chosen which network you want your tablet to jump onto. Head over to your settings panel (swipe down from the top, then tap the little cog icon). From settings, make sure you're in the "Wireless and network" tab. Make sure your wifi is turned on (with the green bar below it). To the right, there should be a list of wifi networks you can join. If there's one that has a little padlock icon on it, it means it requires a password (are you at a restaurant or friend's house? - ask them for the wifi password). If it doesn't have the padlock, it's an open network. Does this help?
Best of luck.
Cant connect to internet
Try entering password again off router. Unplug and replug router then try again. Make sure your WIFI is on too.
2helpful
Wifi connection problem
Need To Double Check Password And Connection Info. One Error Sets The Whole Thing Off As Wrong.
1helpful
Unable to get connected to the internet and the app market
On my Iconia when I see this show up it will be from a low power or a poor wii connection. Basically the signal strength is too low which means the speed drops to the point where everything is timing out before it gets loaded.
There are a couple o causes to check . One is too far from the wifi router.the farther away the lower the signal the slower it goes. You have objects blocking the signal such as steel reinforced safety windows or steel mesh in walls. These can block the signal. I have one are where I'm all of 10 feet away and it will barely connect. I have to move about three feet to the side and get ull strength and speed. The orientation of your tablet can effect i you can use a marginal signal or not. Try aiming the edge with the volume buttons towards the wifi. The antenna is oriented in a way that this will slightly improve the signal. The other thing is that your tablet can be fine but your wii router is having problems with its wifi sections. Certain brands will show more errors and then difficulties in connections in as little as a year old (on some about half that). The Iconia has a rather good wifi ability so I wouldn't blame its hardware but would look at the location orientation etc as I have mentioned.
Top Mach Speed Trio Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
