SOURCE: Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
SOURCE: fujitsu outdoor unit not working
Its possible there has been a power spike and it has dammaged the power pcb. Remove the cover and inpect the PCB's for blackening. If any blakening replace the damaged PCB.
SOURCE: How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
