Do not continue to reset or a fire could occur and that would ruin a perfectly good day :) Code is for the FUSER!!!! (HOT PART) IF CODE COMES BACK replace the fuser
Start:
A. Call the service mode to the screen.(Shifting to the service mode is available even when the service call is occurred).
1. Press the Utility/Counter key.
2. Touch [Meter Count] on meter count display.
3. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
4. Touch [Password], and enter the CE password using the display keyboard or the 10-key pad. Default is 92729272 (get three shots only then you are locked out)
B.Once in service mode use the following procedure
2. Change the screen using [?] / [?] and select [Trouble Reset].
NOTE
• The trouble reset key will be displayed in the service mode only when the service call is occurred.
3. Touch [OK] on the check screen.
4. According to the description on the screen, turn OFF the power switch, and turn it ON again more than 10 seconds after and check to make sure the machine operates normally.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
