Canon PIXMA MP170 All-In-One InkJet Printer Logo
Anonymous Posted on May 18, 2009
How do you find the waste ink collector on a printer/scanner ?
How do you find the waste ink collector on a Canon scanner/printer Pixma MP170
What does the waste ink collector look like ?
Do you need to empty it or change for new one?
I had a message come up on computer screen saying it was nearly full.
Diane
Anonymous
Level 2:
  • Expert 32 Answers
  • Posted on May 28, 2009
Anonymous
Expert
Level 2:
Answers
32
Questions
0
Helped
31223
Points
127
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
5helpful
How to reset canon pixma mp145?
Besides service tool, you can use MPTool software to reset Canon printers MP series. This software support for canon MP150, MP160, MP170, MP180, MP450 and MP460.
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
1helpful
Waste ink near full on my pixma mp170, can you advise
Please follow the instructions provided here and do let me know if it doesn't help. I'll let you know another trick.
FixYa's how to clean Ink Waste Tank Full
Good luck
Thanks for using FixYa.
2helpful
How do I remove the Waste Ink Absober and do I
The waste ink pads are under the printer and cover the whole bottom of the case. You need to remove the scanner from the top, the side covers, the main case middle cover, unplug all cables from the logic board, lift the print engine up and out and replace the pads. After that you need the service mode to reset the counter if it runs after re assembly.
2helpful
Canon Pixma MP150
Besides service tool, mptool is the popularness software to reset printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460. Excess of software that is the program measure of small and amenity of usage. Ability of the software that is to reset level black and color cartridge at canon pixma mp series. And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Reset Ink Counter.
Reset ink counter that is resetting ink level (ink metrer) cartridge at printer.
  • Reset Black – reset level black ink cartridge.
  • Reset Color – reset level colour ink cartridge.
  • Reset Main (main).
  • Reset Platen (additional).
go to this website download this software after that install it follow by instruction that i give to you do reset....
http://www.mediafire.com/file/yan3ytvdumt/MPTool.zip
1helpful
What is the wasted ink collector? A sentence appears when I try to print out a page. It tells me that the collector for the wasted ink is nearly full.
there is a waste ink tank that stores excess ink from the printing process.
it is almost full and would need to be cleaned or replaced. and then the printer needs to be reset. Recommend Canon service for that problem, there are instructions for it posted online if you care to look around.
1helpful
I am getting an on screen message
The waste ink absorber covers the whole bottom of the machine, under the printer. It is difficult to change, and you have to get into the diagnostic mode to reset the error. A shop repair...
4helpful
The waste ink collector is full how do I empty it?
The absorber is under the print assembly, it is a pad and can't be emptied. It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error.
1helpful
How do I find waste ink collector
there no any waste ink collector, this printer have only a pad for waste ink, (you don't need to replace first time indication) only take the printer to service center to reset this indication.
or
for immidiate printing -
just switch off printer from main (power) swtich then push and hold the on key and paper key then switch on from power. (it's work some time in some pixma)
6helpful
The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
2answers
Waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
old marine
old marine
ZJ Limited
ZJ Limited
