Widows doesn't load automatically after the power button i have to press any of the button then only the windows will load. Please help me to move out from this problem
SOURCE: Reformat system - for Sony Vaio - part 2
You have to create the recovery cd using the Sony Recovery Media kit creator program.
It should be in the control panel. It requires 1 DVD and 1 CD-R cd. Or 7 CD-R cds.
You can however use the recovery wizard, but it will erase the Recovery Media Kit. It also can be found by using the recovery wizard in the control panel.
http://www.pctechbytes.com/vaio-recovery.htm
http://esupport.sony.com/perl/news-item.pl?mdl=PCGFRV27&news_id=8
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Sony Laptop wont power ON
1 CHECK THE POWER SUPPLY ADAPTER.
2 CHECK THE DC JACK IN THE LAPTOP.
IF THE VOLTAGE IS COMING FROM THE ADAPTER AND COMING TO THE MOTHERBOARD OF THE LAPTOP THEN THE FAULT LIES EITHER THE FUSE ON THE BOARD OR THE DISTRIBUTION IC WHICH STARTS FROM MAX.
SOURCE: sony vaio cr35 power problem
You might have a hardware failure here. Specially the part when you said you had the same result when removing the battery and just had the AC in. This machine has NO POST this mean Hardware failure specially the blinking light concerns me on the machine health as far as a tech. I would say bring it into the geek squad to confirm my theory it will not hurt for them to take a few secounds to confirm this if there is any warranties I cannot stress this enought use the warranty this is your secure ticket to a fix if its not warrantied I would seriously recommend having the motherboard evaluated it should at least beep but if you do not get a beep this is NO POST hard ware failure. Thanks and please rate you experience with me postivly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Testimonial: "thanks for the advise. I will send it to the service center for evaluation. Thanks very much"
SOURCE: Sony Vaio laptop with Windows 7 and xp install?
You can download the Microsoft virtual machine or another VM system.
Like this:
http://www.oracle.com/us/technologies/virtualization/oraclevm/index.html?sckw=srch:virtual-machine&SC=srch:virtual-machine
After install make a virtual hard drive on your VM machine of at least10 gig. Then add your DVD/CD rom drive to the VM and put yourinstall CD/DVD in the drive. Set VM machine to boot from CD.Install on VM hard drive from within the VM machine, Type in KEY code,Bam! you now have a win xp VM!(Note: Games and stuff may not work in the VM as they do not use your video card but a virtual video card that is pretty limited!)
SOURCE: My sony vaio eb (e series) wont turn on, the power button flashes green! PLEASE HELP!
test all power and data leads that attach to your hard drive SATA the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working check the CPU central processing unit make sure it has thermal paste and dust free secure seating also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Testimonial: "thanks it's kind of helpful but would thermal paste make a difference if i changed it? i think the soldering is out most likely but whats thermal paste used for?"
