Question about Saeco Stratos Coffee Maker, Espresso Machine
Decalcify jura - Saeco Stratos Coffee Maker, Espresso Machine
    New Friend:
  • 3 Answers
First run a Descale cycle from the menu (this will take several hours/overnight). Then hold the steam button for five seconds to reset the code. Good Luck!
Posted on May 23, 2014
SOURCE:
While decalcifying the water comes out of the frother in intervals as it should but it does not come out of the spouts.
I have 3 different coffee machines and all 3 are descaling like you said using only the froter so that is normal .... Unless you misstyped the question
Sep 30, 2015 | Jura Capresso Impressa F7 Espresso Machine
Jura fs50 - "Decalcify".
If you read the instructions in the manual (Page 6) it describes how to descale (de-calsify) the machine. You use a vicious liquid to be used with great care. If you lost your manual go to http://www.coffeesolutions.jura.com/home_coffeesolutions_x/service_support/download_guidelines_jura_impressa_s9otc_english.pdf
Mar 23, 2014 | Coffee Makers & Espresso Machines
Display tap on Jura Impressa E75 say close tap, where is tap please
The tap is the dial on the left turn it, then it will turn the tap off. If it is repeating this then it may need to be decalcified.
Sep 06, 2012 | Jura Capresso Impressa E75 Espresso &...
Is there an easier was to decalcify the capresso 3000 than taking apart the whole machine. The directions say you have to remove the auto cappuccino assembly
Yes
You should run the decalcify program with the JURA decal tablets or DURGOL. Do not use other agents.
See page 25 of user manual.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Jura Capresso C3000 Espresso & Coffee...
Jura impressa f7 decalcifying pressed rinse but does not show empty button as the manual says
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Dec 31, 2010 | Jura Capresso Impressa F7 Espresso Machine
On the screen it is written decalcifying.How do I fix this?
This is a pretty sophisticated coffee maker.. the manual goes into great detail about set up for entering water hardness and descaling messages. There is a discussion about the decalcifying procedure, but none the mentions a decalcifying message.
You should re-read the manual and possibly re-enter the programming again. The manual is available for free, here. Pay particular attention to sections 15, 16a, 20c and 22. These sections are only a paragraph long, but will help explain the filters, decalcify procedure and decalcification tablets.
Please rate this reply - thanks!
Dec 03, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
I am having trouble starting the decalcify program, even though the light blinks "ready/decalcify"
Had the same problem, i noticedt that there is a procedure to run decalcify anytime in the instructions book.
Turn off the machine, press Rinse button until it says Empty Tray then go go Step 2 in the instructions.
Nov 27, 2009 | Jura Capresso Impressa F7 Espresso Machine
Jura capressa F7 steam milk problem
You should decalcify, when you steam the milk some what gets through to the steam and the build up of these minerals causes the issue
Aug 11, 2009 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
May 12, 2007 | Jura Capresso Impressa E75 Espresso &...
Saeco Stratos Coffee Maker, Espresso Machine Logo
64 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
