Question about New Bright Toys
Change remote control frequency
Bought 2 different brands of RC cars but both have 27 MHz can one be changed so they are compatible. one is an Artin RC and the other is NEW BRIGHT
SOURCE:
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Posted on Dec 01, 2009
SOURCE: New 27 MHZ Helicopter Controller won't turn on
I have a 27Mhz helicoper (looks identical to the one on the picture). I tried to fly it for the first time, but I am having problems controlling it. The left radio control lever sends the helicopter upwards, but the right hand control doesn't seem to do anything and that should make it go backwards and forwards. Can anyone help me as well please?
Posted on Feb 22, 2010
SOURCE: We have 2 boats, both
The ONLY way is to use different Channel Crystals in the Transmitter and Receiver, if you can do this, you buy the crystals in Pairs, 1 Xmitt & 1 Rec.
Go to your local Hobby shop, where they sell these types of things and they will be able to supply you with the crystals, usually they simply plug in...
Posted on Nov 25, 2010
terrann238
SOURCE: .My nikko hummer 27 MHz
Heres a link that has the exact remote You need. www.rchobbyexplosion.com/Nikko_Tri_Band_27Mhz_or_49Mhz_Transmitter
Posted on Oct 08, 2012
How can I change the MHz frequency
How to change frequency on RC toy car? - Instructables
www.instructables.com/.../How-to-change-frequency-on-RC...
InstructablesAug 4, 2009 - My friend and I bought 2 rc toys (1:18 scaled Ferrari F1) just for fun, but they work on same frequency (40.685 MHz) so we can't drive at same time. So i need some suggestions on how to change the frequency on one of them. The transmitter have quartz crystal, but receiver have only ...
Modding Fisher-Price 72825 Formel Junior Fernlenkflitzer
www.instructables.com/.../Modding-Fisher-Price-72825-For...
InstructablesI'll show you how to modify a rc toy car to work on a different frequency. ... the method I describe here should work with nearly every rc car. ... if you mean to change thefrequency from lets say 27.005Mhz to 27.415Mhz, it's basically the same.
How to change frequency on RC toys - Instructables
Dec 26, 2015 | Cars & Co Remote Radio Control Street...
My son got a thunder tumbler for Christmas but the car will not turn off, the light remains on. What is wrong?
Probably different frequency remote relative to car, same deal with my sons......car and remotes need to be on the same frequency....either 27 or 49
Dec 25, 2014 | RC Thunder Tumbler Rc Car
Asahi techniplus radio control 27 mhz
27Mhz is a term that describes a broad range of frequencies. 27.1Mhz narrows it down somewhat, 27.14Mhz narrows it down further still and 27.145Mhz is fairly specific for a radio. Many times, these devices support multiple frequencies with a selector switch capable of choosing a frequency that is not already in use. You MUST select the same frequency on BOTH the controller AND the helicopter to communicate properly. Review your instructions or contact the manufacturer if you need more help.
Dec 31, 2017 | Radio Communications
How to change remote control for electric kids ride on car
This is old info. but still applies. Transmitters and receivers normally come as a matched set. They both need to be on the same frequency to work with each other. Look the receiver in the car over carefully and you will see it, probably in Megahertz (MHZ). Open the back of the transmitter (Could be on the front?). Frequencies can normally be set by a switch, especially on a universal replacement. Just be sure they match and it should be good to go. Check the batterys of cource.
Dec 17, 2013 | Electric Eyeware Remote Control Power...
How do I avoid 27.145 MHz Radio Frequency controlled toy car affect by other toy car with the same frequency? Thx
If there is more than one Radio Controlled (RC) devices operating on the same radio control frequency operating in the same proximity - there's going to be an issue for one or both devices.
Simple, inexpensive RC devices operating on the same frequency have no way of being "paired" (like a bluetooth device to a phone) to a particular controller (more expensive devices and controllers have sophisticated ways to get around this limitation by setting codes that allow the device to respond to only the matching controller). You would need to have both the control and device on a new frequency that is different from other RC devices to retain control of the device - otherwise once the device gets close enough to the other controller - it will begin responding to it instead of yours.
In order to use your RC device, you'll need to remain closer to your device than the other controller is. This makes your controller's signal more powerful and should overcome the more distant controller signal. Keep in mind that your range of control will be reduced as the signal suffers from interference from the other controller - much like driving in your car listening to the radio that has 2 broadcasters on the same frequency. While close to home, you hear your local station clearly - but as you get further from the local station, there is an area where the signal from the other station overlaps with your local station - making understanding what is being broadcast by either station completely unintelligible. You have to tune away or shut off the radio until you're closer to one station or the other. Had there been no second station on the same frequency - or had been travelling in a different direction, you might have been able to listen to your local station for the whole trip. The same holds true for your RC device. In an open area alone - you may have control for 200 feet. But in an area with another RC controller operating on the same frequency as yours, that distance may plummet to just 50 feet. The more distance there is between RC controllers and devices competing for the use of the same frequency - the better the experience will be.
I hope this helps and good luck!
Feb 12, 2013 | Toys
Does it matter what crystal i use
Yes. You need to have the same color in both your receiver & your transmitter in order for your RC to work. Both crystals needs to be set to the same frequency. Each color of crystal operates on a slightly different range of the 27 Mhz frequency so the signals don't interfere with each other. That way you can drive your 27 Mhz Rustler with blue crystals and not be affected by your friend who is driving his 27 Mhz Slash with green crystals. Although, if another friend comes along and he also has blue crystals, you won't be able to run your RC's at the same time. The crystal in your receiver will pick up the signal from your transmitter and his since they are the exact same frequency.
Jan 31, 2013 | Traxxas Crystal Set Channel 6 Blue 27.255...
Same remote control frequency for avengers trike
None that I have ever heard of---usually those are burned in the microprocessor circuit the unit uses with the remote.
Only chance would be to contact the maker of each to see if alternate code can be set but I doubt it.
May 22, 2012 | Televison & Video
Nov 04, 2010 | Nikko RC Hummer H2 Off Road Truck
Hi ihave brought helicopter ftw 730 but the remote control was not its own .the helicopter ftw 730 remote control frequency is 40 mhz but the one i have is 27 mhz so how can i make as 40 mhz remote...
Unfortunately you can't. You will need to change the receiver or the transmitter so they are both the same frequency range eg 40mhz or 27mhz. Then you will need to check the crystal is the same frequency for the Transmitter and receiver eg 40.25mhz. NB. you can't put a 27mhz crystal into a 40mhz set or vise versa it won't work.
Aug 21, 2009 | RC Remote Control Rc Mini Helicopter
Toys Logo
153 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
