1999 Suzuki Esteem Logo
Posted on May 18, 2009
Suzuki Baleno (esteem) 1999. Engine Idle RPM not stable
I am running my suzuki baleno (esteem) 1999 (1.3 CC) on Petrol and CNG. The problem is that usually the RPM are not stable at engine idle state. Sometimes they are more and sometime they are less. I have done tunings, but it goes up and down like a wave.
Is it becase of some sensor... or what.... I previously had Suzuki GTI 1.6, it also had the same issue.
  • Anonymous Mar 13, 2014
    the downstream 02 sensor on my suzuki esteem, the wires go into the bottom of the car...where is the plug in at
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2041
Points
6
You probably need to check the butterfly. its the compinent that controls how much air goes into the engine if it is weared than in idle state air leaks into the engine sometime more sometimes less and cause fluctuations in rpm
secondly there is a rpm switch which controls the rpm you can replace that switch and check
1helpful
Is Maruti Suzuki Baleno RS is the worth car to buy?
Maruti Suzuki Baleno RS is the best hatchback from the family point of view. It is sportier and a premium hatchback model with the first in class specifications in terms of looks, safety, engine and performance.
From the interior, the Maruti Suzuki Baleno RS cabin consists of a touchscreen as well as a voice command infotainment system which used for GPS purpose. It has an automatic AC control system along with driver seat adjuster. The front seats are comfortable and provide excellent back support, and its rear seats are spacious in term of leg and head room.
Now heading to the engine and transmission, it has 1.0-litre boosterjet turbocharged petrol engine which makes 102 PS of power and 150 Nm torque. It has 5 speed manual transmission and provides the mileage of 18.1kmpl in city and 21.1kmpl on highway.
The Baleno RS has the excellent ride and handling and offers stability as speed increase. It has overtly light steering in comparison to its competitors, which makes this car worth buying.
For more information about Maruti Baleno RS, check out this video
1999 suzuki esteem front turn signal bulb replacement
lost the operators guide I see.
both books are here.
buy one?
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
buy them used of ebay?
the method is same on all cars,
one looks first. did you?
one looks at the lens, see if there are screws.
if no screws we look on the back side, see if socket twists off.
rare car, few running...
the operators guide.
https://suzukipitstopplus.com/Products/1022-1999-esteem-owners-manual.aspx
here is second google hit.
ever like search much .?>???
http://www.suzuki-forums.com/suzuki-esteem-baleno-forum/55884-front-turn-signal.html
4answers
How to remove and clean suzuki baleno 2001 fuel injector also tell where it is installed in engine.
Cleaning Fuel Injectors - YouTube
? 3:08
https://www.youtube.com/watch?v=MfMkNGlaQZo
Feb 25, 2011 - Uploaded by srmastertech
This video shows an example to what can happen when the fuel filter is not replaced. This vehicle has restricted fuel injectorscaused by excessive dirt in t... ... 2008-2010 Ford Super Duty CabRemoval & Installation Part I ...Missing: baleno
How to remove suzuki baleno blocked fuel injector for - Fixya
www.fixya.com/cars/t10217281-remove_suzuki_baleno
Aug 24, 2011 - How to remove suzuki baleno blocked fuel injector for cleaning. - Suzuki 2001 Esteem question.
Changing a headlight bulb on a baleno
1997 Suzuki Baleno
we dont have Baleno's here on this USA forum (and country)
so cant just look up you book , liker ours.
but the operators guide covers that. lost yours?
here is our.
https://suzukipitstopplus.com/Category/5-suzuki-owners-manuals.aspx
note how Baleno is missing, ? a USA pit stop.!
ask your local suzuki for the missing book, so next time you are ready?
did you open the hood yet and try to find the bulb socket
and lighting laws vary by country , some have auto aiming lights
and are different. (laws gov. these facts)
2answers
RPM problem
Check and lube the Idle Air Control (IAC) valve,
This tiny electric motor is mount on top valve cover and close to the accelerator cable.
The function of IAC motor is to idle up the RPM when more load is added.
Example: A/C on,light on,stop light on and radio on.
A stuck IAC can be free by few soft tape on the body of the motor.
To lube the worm gear,you will need WD-40 to free up the old grease and lube white lithium grease.
Clean the electrical contacts with CRC electric part cleaner.
This electric motor is very expensive.
Please handle it with care.
1helpful
1999 suzuki esteem fuel filter location
This is a Baleno in our market (Australia) and the G16B 1.6 EFI SOHC 16v has the fuel filter bolted to the firewall in the engine bay. This fuel system will be under pressure even after the engine has been off for a long period of time.
Engine pinning when accelerating only on cold Suzuki Baleno
Carbon build up on pistons raises engine compression.This is normal.Go up one grade on gas and/or put some fuel additive.If this doesnt solve it,have timing belt/chain inspected may need replaced
RPM Is Very High On AC Load
check the solenoid that control the engine RPM the solenoid will work if the compressor run, this will increase your rpm when AC on. location near the carburetor.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Suzuki Expert? Answer questions, earn points and help others
