Need help getting front control panel off to replace dryer belt.
SOURCE: whirlpool duet ggw9250pl1
On Duet models, Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
SOURCE: Whirlpool duet electric dryer, not getting any power
Mine shows a faint light behind the control locked indicator and the timer is dimly lit on the two middle horizontal bars (middle of the eights). They go off by pushing various button combos. If I unplug it for a week I can get the control to work for a few minutes.
I replaced the control board, it worked for 5 minutes, then back to nothing. I want to replace the interface but would rather not waste any more money.
I dont want to check every wire for continuity. If someone has fixed this problem, please let me know.
SOURCE: Need belt diagram for Whirlpool Dryer LER5636P
its on the bag of a new belt.but its eazy to put on .put the belt with ribbs down on the drumthis is with the drum on the rollers in the dryer .now have the idler pulley in place and put the belt in between the idler pully roller and the pully bracket,then pull back on the pully and place belt on motor pully.check alinment before starting or will throw belt off again.God bless,tom
SOURCE: I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
