Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Shutter release disabled recharge battery
Shows this problem with a recharge battery message.Tried with full battery charge and still has the same message. the message reads shutter release disabled.
    Top Expert:
  • Nikon Master
  • 6,705 Answers
If you are using the same battery, it could be it has reached the end of life. The charger can indicate the battery is fully charged, because the voltage has reached a correct level, but still the battery can have one or more bad cells. So as soon as you start using the battery, it can lose enough energy to give this nasty message. If you put in another battery and still have the same message, there must be a serious problem in the camera.
To check your battery, just after the camera has given this message, with a multi meter. You will see the voltage has dropped at least 1,2 volt beneath the voltage printed on the battery. The typical 7 volt Nikon battery, will give 8 volt on the multi meter. But placed in the camera it will drop to 7 volt. If the multi meter reading is less then 7 volt it has at least one bad cell and should be replaced.
Posted on Dec 27, 2013
4 Suggested Answers
SOURCE:
SOURCE: Shutter Disabled
i was quated £250 to replace a buckled shutter unit can this be done any cheaper
Posted on Jul 05, 2008
jacko0
  • 159 Answers
SOURCE: Error! Press shutter release button again
I found the fix for this Nikon Shutter problem and posted it on my blog.
http://jacko0.wordpress.com/2009/10/13/d40x-underside/
Posted on Nov 25, 2010
  • 214 Answers
SOURCE: Nikon d80 dslr camera working
HiI am sorry to hear, but you will have to some professional. Regarding your d80 has common problem of sequence unit defective. I believe that is the problem and your local repair shop would charge around $75 to 235 depend on what they really want to charge. Thanks and best regard!
Posted on May 27, 2011
Shutter-release button doesn't work
The manual only can give two reasons why the camera would not take pictures.
One, there is no memory card placed.
Two, the memory card is full.
You are sure you have placed a working empty memory card.
If you did save all the pictures on the memory card to a computer, try formatting the card in the camera.
When you are pressing the shutter release button half, does the camera say it is focused correct? light bottom corner of the display.
Your camera has a setting to take pictures with a remote control. Did you put the camera in that setting? Read page 76 of the manual.
success
Jan 16, 2014 | Konica Minolta DiMAGE A200 Digital Camera
I have cannon digital camera IXUS 255 HS. I
Dear Tejas Belani,
I hope you're still reading this but I had exactly the same problem with the Ixus 255 HS as you describe (full battery - false message - filled battery icon when looking to pictures on the memory card).
After some failed rescue attempts (recharging, completely discharging, 10 second hold of on/off button), I think I finally found it: put a small piece of paper or carton in between the battery opening door and the battery. This pushes the battery a couple of millimeters deeper in the battery bay and ensures a good contact between battery and pins at the other end.
Seems like Canon were a bit cheap on the plastic levers that secure the battery ... or perhaps they erode after some time of usage. This type of camera is often exposed to more aggressive conditions than the bigger, more expensive camera's out there :)
Aug 20, 2013 | Canon Cameras
Nikon d40 low batt info but batt is full charged
sometime if the battery is dead it still shown fully charge on the charger, try change another battery or with new one.
Nov 07, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
My Canon 5D mkI turns on ok, will focus, displays top and back, but it will not take a shot. I have two batteries, both which I have charged to full and tried (display shows full charge). I have also...
hicould you tell me the amount of shot number when you put memory card in? If yes, please move to manual position from auto on the side of lens. And try to press release button.there is other one thing you have to chack selftime release working or not. just let me know.
Jun 04, 2011 | Canon EOS-5D Digital Camera
Wide angle mode switch stuck??
repair... olympus will charge about $60
Oct 02, 2008 | Olympus FE-100 Digital Camera
Shutter Disabled
Jul 02, 2008 | Nikon D40x Digital Camera
Depressing my shutter button on my Fuji FinePix E550 causes it to turn off. When I turn it back on there is a no image message. Is it cheaper to buy a new camera than to have it fixed? Thanks for help
You just need new batteries. That's what the E550 does when the batteries get too low. Please get the latest rechargables. Many of the ordinary AA batteries won't last 50 pictures. Fuji also is rather poor telling you how to charge the rechargables. When the screen goes blue when you take a picture, you must use the camera's de=charging system before recharging--otherwise the rechargables will not take a full charge--that's what's likely happened to you!
Feb 15, 2008 | Fuji FinePix E550 Digital Camera
HP Photosmart 120 Digital Camera
You will need to use 2100 mAh or 2500 mAh rechargeable batteries, as others are not powerful enough. To format the card, look in the menu system (or, indeed, in the manual) for the 'format' command.
Jul 09, 2017 | HP Photosmart 120 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
3,730 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
