Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Shutter release disabled - Nikon D40 Digital Camera with G-II 18-55mm Lens
    Novelist:
  • Nikon Expert
  • 357 Answers
Usually caused by a failure of the motor in the aperture unit.
Posted on Jun 19, 2014
SOURCE:
How to enable and disable movie-record button?
To use the movie-record button, your camera must be in the live view mode.
When you are using the viewfinder (DSLR mode) you only can shoot stills. in live view, you can shoot movies with the little red Movie-record button and shoot stills with the shutter release button.
Sep 05, 2014 | Nikon D5300 24.2 Megapixel Digital SLR...
Long exposure? how dp you acoomplish this using the pentax k-1000
You will need an external shutter release that locks. Connect the shutter release, then on the camera set the shutter dial to B (bulb). With the shutter release cable fire the camera and lock the plunger, or hold it down. Using a shutter release cable you are less likely to cause camera shake. Of course have the camera on a tripod or something steady.
Jan 27, 2014 | Pentax K1000 35mm SLR Camera
Error message nikon d60 release not working
I assume that the full message is "Shutter release is disabled." The causes can be as follows:
1. The memory card is not fully inserted, or locked in place; or the write protect tab on the left edge of the memory card is in the protected position. A full memory card could also cause this problem.
2. You are using an automatic lens equipped with a focusing ring and you have failed to lock the aperture at the highest f-number by sliding the locking tab on the lens.
3. You are using a non-CPU lens, in which case you must rotate the mode dial to "M" and manually set your ISO, shutter speed and f-stop.
4. Your flash is not fully charged.
Dec 05, 2013 | Nikon Cameras
Fuji s2700hd
I'm afraid this camera does not have any possibility to do manual focus. Not with stills and for sure not with recording video.
The only thing to help you focus on a certain object, that is not in the centre of the frame, is the focus lock. You have to point at the object you want to focus on, then press focus lock and than you can choose the composition you want to shoot. Focus lock occurs when you press the shutter release button half.
For video, the manual only says put the rail on the film camera and press the shutter release button once. The video will be stopped after 12 seconds. (or when you press the button again.
That is all.
Nov 21, 2013 | Fujitsu Cameras
My shutter release button on my Nikon P500 is not working. I press it half way and it will focus, but, when I press it full down it will not capture the picture. It started happening suddenly last week....
Try pressing the "Menu" button and disable "Active-D Lighting", also try setting the "Autofocus mode" to "Single". When the camera is off, press the shutter release and twist with the zoom know back and forth. Hopefully that fixes it! It worked for my P500 with the same problem.
Sep 25, 2013 | Nikon Cameras
I have a Nikon D80. When I went to use it recently (having charged the batteries) - the shutter would not release every time. I can find no reason for it - it is an intermittant fault. Can you help?
The shutter will not release if the camera is unable to obtain focus. If the switches on both the camera body and the lens (if equipped) are set to auto focus, the camera will prevent the shutter from releasing. The most common cause of a focus problem is the lack of light. The "focus assist" light on the front of the camera will come on automatically for a moment in dark places to help the camera gather enough light to focus. If you haven't disabled the light in the menu, make sure it isn't obstructed.
You can override the whole auto focus issue by setting the switches on the camera / lens to "manual focus" instead. Of course, this means that you are shifting the responsibility of focusing from the camera to you. The camera will release the shutter every time in this situation.
If you still have problems, provide the mode you're running and the lens you're using & I'll try to help out some more. I hope this helps & good luck!
Oct 11, 2011 | Nikon D80 Digital Camera
It says shutter release disabled..... how did that happen
Having received no response in over a month, I assume this is no longer a problem.
Aug 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Nikon D40X
Press the down arrow until it disappears. That should disable the data view.
Jul 06, 2008 | Nikon D40x Digital Camera
Shutter Disabled
i was quated £250 to replace a buckled shutter unit can this be done any cheaper
Jul 02, 2008 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
202 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
