Red light goes on, does not blink, shuts off within 30 seconds. never turns different color. Copter doesn't charge.
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
