Wm2233hs
If you are referring to the adjustable height feet under the machine I would suggest what is called a Headset Spanner for bicycles. The space under the washing machine at its lowest height is very limited, only a few millimetres. The Headset spanner is very thin and can access the adjusting nuts at this height. These spanners are about eight pounds from Halfords and usually have four different nut sizes on each spanner, two at each end. If you can borrow a head spanner so much the better. These spanners are used to tighten the large nuts that hold the handlebars (headset) to the frame of the bike.
