Radio Codes and free advice are always available here
www.ukbookshelf.co.uk
Mention FixYa Forum
______________________________________
Ford M Serial Number radio codes available 24/7....with no waiting
www.radio-codes.webs.com
Renault radio codes now available here 24/7....no waiting
www.ukbookshelf.co.uk/RENAULTWeb
You shold have the number in your owners handbook if not you can go to main dealer with v5 log book and id licence etc they will give you the code it may cost 10 pound
SOURCE: where do i locate the
Thermostats can most always be found where the top radiator hose connects to the block. The casting piece that the hose connects to is located there.
SOURCE: inner door panel removal, renault megane scenic
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
SOURCE: Hi I need to unlock the cd on my renault
go see your renault dealer and they will give you the code also might be in front of your service book it a 4 digit code
SOURCE: need code to unlock radio for my Renault Megane
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Please
quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL
CASING.
There
should be a 14 character Serial Number beginning with RG or RN or PH or similar
(often found stamped in the metal casing ) and maybe a Security Number in the format of
TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING
you can find
Unlock code is 1770
