You need unfreeze code?What is the model?I suggest you can approach Onlinegsmunlock.com and specify the model,country,locked network.Based on the availability you can get the unfreeze code along with free instructions for your Tab.
Here is how you fix this problem: Hold both the power button AND the volume UP button down at the same time for about 5-10 seconds it should restart. You don't lose any info doing this.
Try this lol, This works with devices having physical home button:- 1. Press the power button and the home button together
for a while, long enough until the screen appears with Android bot and a
progress bar which shows that it's formatting the internal memory. With NO physical HOME button:- 2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds. 3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings. NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
If the iPad is frozen and can't be restarted the normal way,press and hold the sleep/wake button and the home button together for at least 10 seconds.The red slider may appear and the screen may dim but don't release the 2 buttons until the apple logo appears.If this doesn't work,you will need to backup and restore the iPad.Upgrade to latest version of iTunes,then connect to computer and select it when it appears under devices.If you haven't done a sync do so now.Click summary tab and then restore.If you haven't done a backup you will be prompted to do so.This will backup all settings on iPad..Next click restore and if you have completed all steps,wait until iPad completes the restore and returns to home screen.
