Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Door locked after shutting down cleaning cycle earlier than
Hi when i pushed the auto self clean button ,i did not specify a time because clock stated a start time and a finish time 3 hours later. i hit the cancel bitton after 2 hrs...its been 2 days and the oven door still will not open model is a kitchen aide convection wall oven superba about 8 yrs old,,,i cant see model # it is inside oven door...Please Help????
  • 10,865 Answers
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
SOURCE:
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
Self-Cleaning Door Locked
Would like to download user manual for hotpoint sh83ck
May 02, 2013 | Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
722 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Steve Allison
Steve Allison
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
