Komono Wizard Heritage All Black, Mens, Black Logo
A
Anonymous Posted on Dec 25, 2013
Komono battery replacement - Komono Wizard Heritage All Black, Mens, Black
1helpful
Why did hands come off during watch battery replacement?
If the hands of your watch have come off after replacing the battery, it could be due to a few different issues. Here are some possible causes and solutions:
  1. Improper installation: If the hands were not properly aligned when the battery was replaced, it could cause them to come off when the watch is turned face-up. Make sure that the hands are properly aligned and securely fastened to the watch movement before reassembling the watch.
  2. Loose or damaged hands: If the hands were loose or damaged before the battery replacement, they may have come off when the watch was turned face-up. Check the hands for any damage or wear and if necessary, replace them with new hands.
  3. Damaged watch movement: If the watch movement was damaged during the battery replacement process, it could cause the hands to come off when the watch is turned face-up. Have the watch movement inspected by a professional watch repair technician.
  4. Incorrect battery size: If the incorrect battery size was used to replace the old battery, it could cause the hands to come off when the watch is turned face-up. Make sure you are using the correct battery size and type for your watch.
  5. Incorrectly set the hands: During the battery replacement, if the hands were moved or set incorrectly, it could cause them to come off when the watch is turned face-up. Double check that the hands are set to the correct time and position.
Oct 31, 2022 • The Watches
GB5. How can I replace batteries?
All watch batteries can be replaced, even gold watches.
BIG Battery!
https://www.google.com/search?q=GB5+replace+battery
The problems of not having full 'make model (what it is)'.
Jun 13, 2019 • The Watches
1helpful
VX82 X530 Battery for Pulsar watch
The VX82 X530 battery is a replacement battery for the Pulsar watch. It is a lithium-ion battery with a capacity of 3.7V and 530mAh. It is important to note that you should only use a battery that is specifically designed for your Pulsar watch, as using the wrong type of battery can damage the watch or be potentially dangerous. Always use caution when changing a watch battery.
Yyou can try searching for "VX82 X530 replacement battery" or "Pulsar watch battery replacement" on online retailers such as Amazon, eBay, or Alibaba. You may also check with the manufacturer of your Pulsar watch or a local watch repair shop for replacement options.
Trying to set my timing where do u adjust it at
Got a Komono Powergrid today myself and I just set the time. Hold the bottom left button until you 00.00 displayed. then press again until the date is displayed. For example 4, 30. Hold button until first digit flashes. Then use the top right button to adjust, pressing bottom right button whilst screen is flashing will move to next digit allowing you to adjust etc. Hope this helps. Not sure what all the other buttons do yet.
Apr 30, 2016 • Watches
1helpful
Hi I didn't get any instructions with my KOMONO POWERGRID solar panel watch Can someone who has one take a photo of there's? I want to know instructions and functions Thanks Linda
Google for instructions for your watch make and model. (The model number is usually on the back.) The manual may be online.You can then bookmark stand go back whenever you need to. You may also find a Customer Service address, to ask for a manual.
Nov 17, 2015 • Watches
5helpful
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
9helpful
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
2answers
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Top Komono Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Komono Watch Expert? Answer questions, earn points and help others
