RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
Posted on May 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need codes for rca universal remote rcr312w. for apex tv
I have remote control by rca. model rcr312w. need to program apex tv
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 14, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1170
Points
0
Rca universal remote rca312w has no code search button what button what are you use as code search
Steve Allison
Level 3:
  • RCA Master 5,569 Answers
  • Posted on May 17, 2009
Steve Allison
RCA Master
Level 3:
Answers
5569
Questions
Helped
2002658
Points
16452
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
What is the remote code for apex dt-250
These are the set up codes for Apex TV with RCA RCR312W remote control.
10156, 10748, 10879, 10765
3helpful
2answers
Apex codes
Hello
You are seeking codes with RCA systemlink-3 remote control to Apex TV. Unfortunately, there is no setup codes for Apex Tv with this remote control. It is very difficult to gat a remote control that has setup codes for Apex Tv.
Comcast On demand custom-3 universal remote control has codes for Apex.
Codes are :
0748, 0765, 0767
OK.
Need codes for rcr312w remote for my apex tv.
While looking for the codes for your remote I found that you can program your remote without actually knowing the code. It also says one of the problems with the instructions is that they don't tell you about the reverse button having to be repeatedly pressed every two seconds. The codes for Apex Digital TV's are: 10156,10748, 10879 and 10765. Hope this solves your problem.
2helpful
CODE FOR RCR312W FOR MY APEX TV
Turn on the TV, Press and hold down the TV button while entering one of the four digit codes, if the ON/OFF turns off on the last digit entered, that's the correct code, if not, repeat steps, using a different code until it does..here are the codes,..1137,1141,1235.....hope this was helpful...
Lost RCA Universal Remote booklet for model RCR312W remote.
you need to supply the SONY TV model just do a google of any URC booklet and then look uo the ctrl codes for your TV it has little to do with the brand of the remote
please rate our help to keep service online
2helpful
I need code for zenith tv to program into rca remote #rcr312w
Hi cuddles3634!
For that remote, the tv codes are:
Zenith 1000, 1006, 1049, 1054, 1078, 1116, 1133, 1167, 1170, 1172, 1207, 1230
If the TV is digital: 1016
Hope that helps!
91helpful
9answers
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
16helpful
6answers
2answers
RCA universal remote RCR312W
Battry leaked on the steps for programing RCA remote. No Model # found. Is there a list and Picture I can choose from or a code list..... Help Bill
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
