Coby Kyros MID70164G 7Inch Android Internet Touchscreen Tablet Black Logo
A
Anonymous Posted on Dec 25, 2013
Digital 2 tablet will not start
Will not start
How to reset a Lindsay 10" tablet
Click RESET key to see if can start up. b. The way to start the tablet PC's reset function: One hand presses the volume+ or volume- (Please pressing with your finger and do not release it), and another hand repeatedly click the Power key for two times until the screen shows system recovering status.
FAQ Tablet - Linsay Digital
https://linsaydigital.com > content=FAQ-Tablet
How do you reset a digital 2 tablet without volume buttons
If your Digital 2 tablet doesn't have volume buttons, you can still perform a factory reset using the following steps:
  1. Power off your tablet: Hold down the power button until your tablet shuts off completely.
  2. Hold down the power and home button: Once your tablet is powered off, hold down the power button and the home button simultaneously. The home button is the physical button located on the front of your tablet, usually below the screen.
  3. Wait for the recovery screen to appear: Keep holding down the power and home button until the recovery screen appears. This may take a few seconds.
  4. Navigate the recovery menu: Once you see the recovery menu, use the touch screen to navigate the options. Select "Wipe data/factory reset" using the volume buttons on the screen.
  5. Confirm the reset: Use the touch screen to select "Yes - erase all user data" and confirm that you want to perform the factory reset.
  6. Wait for the reset to complete: Once you confirm the reset, your tablet will erase all user data and reset to its original settings. This may take several minutes to complete.
  7. Restart your tablet: Once the reset is complete, your tablet will automatically restart. You'll need to go through the initial setup process again, like you did when you first got the tablet.
Please note that a factory reset will erase all of your data, including apps, contacts, and media. Be sure to back up any important data before performing a factory reset.
How do i get the safe mode to turn off?
Did you try turning the tablet off and back on?
If that doesn't help, try uninstalling the last application you installed and restart your tablet. That should hopefully start your tablet out of safe mode.
My Fisher Digital Tablet 7.1 completely stopped working, all the applications already in the tablet won't turn on "Google Market" or anything for that matter. Pop ups saying everything has stopped
I AM HAVING THE SAME PROBLEM, MY FISHER DIGITAL TABLET 7.1 HAS FROZE ON THE INTRODUCTORY SCREEN, I HAVE TRIED THE HOLD VOLUME BUTTON DOWN+POWER BUTTON AND STILL DOES NOT WORK, I HAVE HELD THE POWER BUTTON, PLEASE HELP ME! I HAVE ONLY HAD IT 2 DAYS! :(
2answers
Pandigital will not start up
1. Is there voltage from charger to plug (Volt Meter Needed) 2. Has unit been dropped or wet 3. How long has unit been down?
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
