I have GE harmony profile wpgt9350c0ww ,it goes out of balance and it tries to rebalance 3or 4 times in one wash cycle and eventualy it stops and says laundary is not balance , and cloth are still very wet. I have checked self diagnostic mode and the codes are '' The inverter pcb has a history of not running properly' and 'serial commuications link between main pcb and inverter pcb is down" . I'll appreciate your help.
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor. PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
first I would to a hard reset unplug washer and dryer for 30 sec then plug back in... also check the wire that connects the washer and dryer ....if this don't wark let me know I can tell you how to get the error codes out of it... let me know
GE Profile Harmony
1 press power ( to wake up washer) 2 press Home ( it may already show HOME) 3 press HELP 4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
