PC currently has an SATA disk and a DVD drive. I have connected the ATA on to the IDE to the top of the IDE and moved the DVD to the middle connector. As memory serves me top is Secondary and primary is middle.
I removed the jumper from the ATA hard drive but DVD still has this in. I do not fully know the jumper positions but could you advise me what to do here please?
XP is not recognising the disk and is not in disk management either.
Bios can see 2 hard drives but no DVD.
It is too early in the morning to be peeing about with this.
I dont quite get how you've got them connected so I'll tell you how I'd do it.
First of all, it is kind of standard to put the primary drive at the end of the cable but it doesnt really matter. I go with what ever physically works best.
Connect your 2 IDE devices to the same IDE channel (cable) unless you have 2 IDE channels then put each on their own channel or cable. Make sure you are using 60 conductor cables for each.
If both are on the same cable: Set the dvd's jumper to slave. Set the hard drive jumper to master OR vice versa. *Some DVD burners do not like to be slave, or even on the same channel as another device.
The following is the ideal set up If each is on their own channel (cable): Set each to master
Be sure bios is set to auto detect for all channels, master & slaves. ** If this doesnt resolve your problem, please post a comment before rating.
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive)
The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20. If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows: Connect the ATA IDE to MB primary master IDE port. Connect the ATA SATA drive to the MB's first SATA port. ATA Configuration Set as, [P-ATA+S-ATA] S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller. P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller. On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]". Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three. First boot device [Floppy] (If you have a floppy disk drive connected.) Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master. Third boot device [ATA IDE drive] If your boot drive is the SATA drive than set: third boot device to the SATA drive. (Hard disk drive with operating system loaded on it). Save your changes & exit the bios. Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number. Save & exit the bios. The system will auto restart. Windows should start.
XP does not have a SATA driver on the installation CD, you need to either download a SATA driver and when XP ask at the start of the installation you need to provide a SATA driver for the hard disk, press F6, the driver is usually installed from the floppy disk.
Alternately if your BIOS will allow you to set up the SATA drive as a ATA drive, do so and after XP is installed then install the SATA driver.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Balls.... IDE is wrong way round to start off with...
Still have not solved issue.
