SOURCE: sound problem on Sony TA-343 amplifier
If you're not experienced with troubleshooting and repairing electronics, I strongly suggest professional service. There are internal problems and most likely several components will need replacement.
SOURCE: Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
SOURCE: AUDIO AMPLIFIER'S ONE CHANNEL DEAD
Hi there.
Check for shorted speaker wires on left channel. If not, disconnect speaker wires and check to see if headphone jack works. If left works, you may have a blown speaker. If left still doesn't work, left power amp blown.
Thanks
Paul
SOURCE: HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
SOURCE: With my amplifier sony TA V902 I don't have sound
when you amplifier is powered on if the speakers are powered on and you hear that the output is switch on then it is possible that the fault of the amplifier is in the preamplifier.Open the set and check on the input of the amplifier with a signal . If there is output the fact is confirmed of the preamp stage. Now we have to confirm if the fault is in the source swtiching or the preamp equaliser/ tone section. Using a good signal tester and hoping that you are familiar to handle the electronics inside, the IC can be identified and changed. Use extreme care and test at low output, Use a help of an expert to signal trace the fault. Hope I could help. Good day
