Question about Intel Motherboard
Sata cable & pata cable have a any jumper setting
    Problem Solver:
  • 10 Answers
The hard drive / optical drive have jumper settings, not the motherboard. PATA has jumper settings, but SATA do not require any. The diagram of the setting is drawn on the hard disk itself below the serial number etc. For SATA, look on the motherboard for the SATA ports. Each port will be named as like SATA 0, SATA 1 etc. If you want the hardd disk to boot first, plug it in SATA 0. and the next device in SATA 1. However, you can also set the first and other boot device from the BIOS itself, in case of SATA.
Posted on Dec 27, 2013
2 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: Sir , I have an Intel D102GGc2 Motherboard .I
One needs to be a master and one needs to be pegged as a slave. You can have seperate OS..Win 7 on ons and XP on the other then at post screen you can select which OS you want.
Posted on Nov 27, 2010
Western digital wd2500bevt slave jumper settings
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
Feb 06, 2014 | Western Digital WD Scorpio Blue WD2500BEVT...
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
Pata slave drive not found in bios a05 of dell dimension 8400 but found in windows and linux os's
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
Mar 17, 2017 | Dell Dimension 8400 PC Desktop
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
NO CHART ON IT TO TELL ME HOW TO JUMP IT SO IT KNOWS WHETHER OR NOT ITS THE MASTER
PATA HDD's (the ones that take the ribbon cable) have had the jumper settings printed on the label for the past 10 years. Different makes have different settings so we would need to know the make and size of HDD.
You could also use trial and eror without damaging the HDD.
SATA do not have jumpers as they are "cable select" and master is normally the one in the first SATA connection on the MoBo
Dec 17, 2009 | Compaq Computers & Internet
Trying to install a Samsung PATA 160GB HD in my recently bought ued Solo 5300.I see no cables etc, just some pins at the back of the HD slot. Do I need to take the whole unit apart to get at any cables?...
larry, is your motherboard PATA capable? meaning, are there 4-8 red female connectors on your motherboard?
If there is no compatibility with your PATA/IDE Motherboard, you can purchase at any local computer shops PATA-IDE converters... ranging $15USD.
This converts the PATA DATA+Power to your motherboard.
The HD you have requires Jumpers. Hence why they look like card slots on the back.
Before purchasing any cables, be sure to notice if your motherboard is PATA capable and relieve less stress on you :)
Aug 27, 2009 | Gateway Solo 5300 Notebook
Hard drive is not working, waspurched one year ago.
This issue has many various factors on why a hard drive doesn't work the way it should be. Let's discuss it one by one:
First, ensure that all the cables ( SATA/PATA )are properly seated or attached to your MOBO. If the cables were checked, makes sure the molex which gives power to the hard drive is connected.
If all are in place, then a Primary & Slave of hard disk issue is another factor. Lets assume that you are using a PATA or IDE cable. If you are only using one IDE cable as of this moment an issue of setting your jumpers on their proper places. Make sure each jumpers are on the right places, the Master jumper ofcourse that should be on your Primary HDD ( w/c ofcourse w/ O.S. ) and the other HDD its jumper is on the slave.
Another one if the ( PATA/SATA ) is properly seated on the controllers of your hard drive.
Also, you try isolating the cables. Probably, the cables you are using are not working, obselete and needs to be replace.
Lastly, does your hard drive spins? Do you hear any clunking sounds? Then, it only means an issue of hard drive failure had arised and needs to be replace.
Sep 09, 2008 | Computers & Internet
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Intel Motherboard Logo
109 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
