Question about Intel Motherboard
6bx/via zx86 ver:1.7
Where does usb 6bx/via/zx86 ver:1.7 motherboard
What is the Front Side Bus speed of MSI MS-7312 ver 1.0 motherboard
MOBOT Motherboard Spec Sheet MSI K9MM MS 7312 Motherboards org
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet Powered by MOBOT 10428.jpg Part Number K9MM-V (MS-7312) Manufacturer MSI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset VIA K8M800 VT8237R+ North Bridge VIA K8M800 Socket Socket AM2 (940) Processor Types Athlon 64X2, Athlon 64FX, Athlon 64 Number of CPUs Front Side Bus 800MHz HyperTransport Bus Link Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP VIA UniChrome Pro South Bridge VIA VT8237R+ Audio 6-channel IDE SCSI None SATA 1.5 GB/s RAID LAN Firewire None USB USB 2.0 Expansion Slots BIOS AWARD Form Factor microATX
Jun 05, 2014 | MSI K9MM-V Motherboard
Driver for sound card for motherboard 6BX/VIA/ZX81 VER. 1.7
Best is to go to the site of the manufacturer of this mainboard.
At driverguide.com I could find information about a file, called
File Name: 6bzv81.zip(1.8 MB)
When checking this filename back at google, I got the link you're looking for :
http://www.eserviceinfo.com/downloadsm/37323/Acorp_6BX/VIA/ZX81.html
Success !
Oct 13, 2013 | Intel Motherboard
MSI K8T Neo 2 not recognize Hitach 1 TB Sata
This is a quote from VIA:
"CHIP FIRM VIA issued a note to its customers telling them of problems with chipset support for hard drives using the Serial ATA II standard.
It said that VT8237 and VT8237R chipsets don't provide forward compatibility for S-ATA II, which is important as hard drive makers are beginning to manufacture this type of drive.
But Via is readying the release of VT8237R Plus, which will solve the problem. This means that motherboard makers that use the former chipset should clear their inventory before September.
Hard drive manufacturers position with S-ATA II is as follows, said Via in its note. Western Digital and Samsung are already shipping these devices, while Seagate and Maxtor will start shipping them during this quarter.
If you connect S-ATA II drives to an old Via chipset which includes the VT8237, VT8237R, VT6420 and VT6421L, the devices won't be detected.
Some mobo makers, such as Epox, have already responded to the problem and have warned their customers to seek the support of hard drive vendors. In a letter to its customers, it said that they should also check the specs of other manufacturers' Via based motherboards."
Jan 11, 2010 | Computers & Internet
I want THE Driver of MS:7312 VER:1.0 VIA Mother
Do you mean the VIA chipset drivers or the entire Motherboard drivers? Audio, Sound, chipset, etc....
Jan 03, 2010 | AMD Computers & Internet
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
ACORP 6bx/via/zx81connectors
http://images.google.co.uk/images?gbv=2&hl=en&q=where+does+hdd+led+and+pw+led+wires+go+on+gigabyte+motherboard&btnG=Search+images
click on this link and it will take you to some images of various motherboards and where the leads go.
I hope this helps
Nov 02, 2008 | Intel Motherboard
Problem with audio driver
haii,
Im using ms 7173 ver 1 motherboard and via chipset VT8237R and AMD sempronprocessor. I have problm with my audio driver so pls help me for downloading the corresponding driver.
Thanks
Sajeesh
Jul 08, 2008 | MSI K8MM-V Motherboard
Audio driver ms7142
I'M IN NEED OF SOUND DRIVER AND VIDEO DRIVER OF THE MS-7142 VER:1 MOTHER BOARD
Jul 07, 2008 | MSI K8MM-V Motherboard
Usb ver update
There is no available update for the USB that was already designed for the manufacturer that you can only avail 1.0 version.
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Nov 23, 2007 | Q-Lity 810E-T (P3810E-T) Motherboard
Intel Motherboard Logo
82 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
