Question about Technics SL-1200 Turntable
Tone arm skip back.
My tone arm keeps skipping back to the start of a record when you backspin/ cue, even when it is moved very gently. I found when you tap the arm, when it is on the armrest, it swings backwards. It is not just that the anti-Skate is not working. It really rips back alot.
Please Help
Daniel
  • skee mask Apr 16, 2008
    tonearm keeps going to armrest.
    Problem Solver:
  • 7 Answers
You most likely have broken balls,,, lol yes balls bearings are most likely broke you might have to replace your arm.. about 80.00 for the part
Posted on Oct 19, 2007
6ya staff
SOURCE:
I have a classic model CSL1 all in one home stereo while playing a record it suddenly starts hopping what do I do
"Let's go to the hop."
If the tone arm is 'hopping'; that is, bouncing up and down. Either the turntable platter or the motor itself is not moving freely and causing a vibration.
If it is just 'skipping the needle is not going down into the groove on the record, There may be a build up of dust or lint on the needle keeping it from following the groove, therefore it ;skips'.
Also the needle tip may be worn. If it is skipping, you can try cleaning the needle with a soft makeup brush. brush gently back and forth, (the way the groove in the record goes.) NEVER SIDE TO SIDE.
Sep 04, 2018 | home Audio Players & Recorders
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Technics SL-1200 Turntable Logo
522 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
