We have a frigidaire (model #PLEF398CCC) convenction oven. The other night while baking and cooking on the stove top, we heard a loud "pop". The next day when I tried to use the oven again, it would not heat up. The oven bake, broil, convection and warming drawer in the bottom all fail to heat at all. I have been looking at other consumer problems and can't figure out whether it is the control board or just a fuse. Any suggestions?
My model number ends in "CCC" not "AC" as listed below.
Oven elements don't work and control panel is flaky. Sevice guy said power board and EOC needs to be replaced. $800 parts and labour.
I bought extended warrenty for 5 years which expired 6 month ago
SOURCE: oven not working
It is most likely that the oven heating element has failed, which would be the likely source of the 'bang' you heard, you may also need to check the oven temperature control sensor as this may have gone out at the same time.
SOURCE: Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
