EliteGroup GF7050VT-M Motherboard Logo
A
Anonymous Posted on Dec 24, 2013
Not booting or beeping GF7050VT-M
Interupt cpu0 fault
2helpful
3answers
Just upgraded Vista to Windows 7. Now when computer boots, it repeatedly beeps (so many times I can't count them), then asks which OS I want to start with. Only Windows 7 is listed. It starts fine.
Hello, if your computer peeps on startup it could be that your keyboard is stuck somehow thats why it beeps, it is sending and interupt request. try checking your keyboard to be sure its not stuck. happy new year
5helpful
Hi i want lan driver for GF7050VT-m motherboard. I want to use windows XP.
be 4 you use the land card pls check the bios if it enable then that is the time you download the software driver of the gf7050vt-m
5helpful
2answers
Gf7050vt-m5 Drivers
We have to go to the manufacturer in order that we get information. We need for them, the name of the computer, the model number and the MB ID needs to be reconfirmed. You will find the numbers for the MB in between the white PCI sockets, the lettering is so profound that you cannot miss it. If they have changed location, then you will find same around the upper right corner of the MB, around the RAM memory sockets... Thank you for your consideration of our service...
My name is Constantin (arzconst is my nickname for Fixya.com).
1helpful
2answers
My driver was missing and I need a driver
Here is the download page for your motherboard's drivers, BIOS, and manual:
GF7050VT-M5 Downloads
Thanks for using Fixya.
1helpful
NO POWER
If you have changed the power unit and the computer is still not powering up, then it is quite likely there is a motherboard fault - probably in the power management circuitry, which expects the power_good signal from the power unit at a precise moment in the boot up process. A fault in the power management circuitry would prevent the computer from beginning its boot-up process.
Do the fans in the power unit come on when the computer is switched on? If they don't - this suggests a power unit problem. If the power unit fans do start working but the computer still doesn't boot, this suggests either a faulty or 'dry' connection (easy checked) or a motherboard fault.
If your computer 'works' but nothing is displayed, try pressing Control+Alt+Delete. If it then boots up it suggests a power unit problem. If not .. we come back to the motherboard again.
A low wattage power unit can cause the problem you describe. Every 128 Mb of Ram needs 4 watts of power. Add more for the motherboard (up to 30 watts..) then the floppy/hard drive/dvd etc .. If the power unit can't supply the necessary wattage, it won't boot. The older 250-300 watt power units aren't suitable for modern computers with XP/Vista. Ideally, you should be looking at 400 watts plus -it will tell you on the power unit.
Though to be honest, it does sound like a motherboard fault.
The only other thing that can cause a computer not to boot up (though it will begin the boot up process) are other faults ... When you switch on does it actually display anything on the screen .. and are there any 'beeps'? 1 beep indicates everything is ok .. 3 short beeps and 1 long beep indicate a memory problem (and the computer won't boot..). 8 beeps indicate a video problem (and nothing will be dislayed on your screen). Same with 9 beeps .. which indicates a bios fault - and the computer won't continue the boot process.
If you have nothing .. no power whatsover ... it comes back to the power unit/mainboard. If you're happy that the new power unit you have put in is ok ... suspect the motherboard. If you have access to any unwanted or 2nd hand motherboard ... connect that. If your computer boots up ... its the original motherboard at fault.
Alternatively, rather than replace bits and pieces at random to cure the fault, take your computer along to a computer shop. It will take them minutes to test it for you and identify the fault.
Beep sound
Can you tell me what motherboard brand or chipset you have ?
examples
Intel , nvidia , via
also I would need to know the exact numbers such as
intel440bx or lx , nvidia nForce2 , via VT82686A or B
Or you can simply tell me a brand name
eMachine , Compaq , Dell , Toshiba , or Gateway
and the specific model number.
Then I can help you.
SunFire 280R
Replace CPU0. If you have more then one CPU, try to switch them around.
If you need a replacement CPU send me an email with the CPU P/N to [email protected]
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
