EliteGroup GF7050VT-M Motherboard Logo
A
Anonymous Posted on Dec 24, 2013
Not booting or beeping
Fans working on ps and cpu.
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • EliteGroup Master 2,226 Answers
  • Posted on May 03, 2014
James Miller
EliteGroup Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447502
Points
2985
1 Related Answer
Anonymous
  • 155 Answers
  • Posted on Oct 19, 2007
SOURCE: Will not boot up
Disconnect all the disks and CD, remove memory and everything else including all the added card (Video, network,etc..).
Power up with processor only and if you don't hear any beep you have a bad motherboard or processor.
If you have any beep power off and add the memory and try again. Keep adding one component at the time until you discover wich one is creating an issue.
PS Did you verify compatibility between motherboard and processor?
IBM x3400 7975 will not boot
No posting can mean any one of the components on the motherboard are not functioning properly. If the Powersupply is providing power to the mainboard you should see the light-diode indicating the PS is operational. If NO diode is lit, the Power Supply is a problem. Assuming the PS is OK and all connectors firmly in place; check all Fans for activity., especially the CPU cooling devices. If all seem to be operational, then the lack of posting could be either the CPU or Memory.
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
On board led indicators are red in motherboard TF7100P-M7 power supply works cpu fan works both fans of the CPU heat sink assembly and power supply fan spin It shows no display, No beep
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
2answers
NO VIDEO OUTPUT
Sounds like a dead motherboard, i had the same problem a while back, with my custom built pc, that or try a new power supply. but i'd say it was the mobo though. a new one cost as cheap as 40 bucks i'd say depending on what your hardware is, you friendly neghborhood pc shop can help you, fyi, build your own pc its cheaper!
2answers
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
2answers
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
2helpful
2answers
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Home built 4 yr old pc wont boot
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Will not boot up
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
