Baumatic B180 Electric Single Oven Logo
Posted on Dec 24, 2013
Can't see/read the temperature markers on oven
When I turn on my oven, I can't see or read the temperature settings on the dial or the oven settings on the other dial. There are markings there but they do not light up or stand out clearly.
1 Related Answer
Ian
  • 51 Answers
  • Posted on Jul 25, 2007
SOURCE: What do I do now that the temperature markers have been scrubbed off??
Go to www.baumatic.co.uk then go to their online catalogue. Find your oven model & download the user manual. You will find 2 very clear pictures of the facia. Regards
6answers
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
1helpful
2answers
Can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
I DON'T KNOW HOW TO SET THE OVEN TEMPERATURE.
Normally you just turn the dial to the required temperature as indicated on the dial.
Usually the oven dial will say 'main oven' or have a symbol indicating which it is.
Sometimes it is a digital display and you have to press a button until the required temperature is displayed.
1helpful
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 • Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 • Ovens
2helpful
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 16, 2009 • Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
1helpful
Top Baumatic Ovens Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
How-2-Repair.com
How-2-Repair.com
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
