Question about Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
Handle won't flush - Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
The flush valve gets stuck after each flush
Often it's the rod just inside the tank that is hitting the white nylon nut that tightens the handle. Hold handle and bend rod up a little. Over time people sometimes push too hard on flush handle it tweaks that rod.
Jan 30, 2015 | Home
Why won't my jacuzzi toilet flush
You just check the chain inside the water closet where the one end is connected into the flush handle,and the other end is connected to the flush valve (it is the rubber cap which is covering the outlet of the water passing into the toilet bowl itsef)..most common problem is the chain is cut,or sometimes it is just need to udjust shorter thats why it can tug the flush valve when you pull the flush handle.
Sep 12, 2014 | Home
How to fix a toilet tank that won't flush unless you hold handle down for awhile.
Check to make sure the chain fromanagement the trip lever to the flapper does not have too much slack in it if there is shorten the chain so when the lever is down there is just a little slack in the chain. Hope this helps
Bob
May 29, 2013 | American Standard Home
The handle bars won't go back in on my bike
Line the bottom thing up to make it flush and then insert it then tighten up the Allen key on the top
Apr 06, 2013 | Cycling
Cistern water won't fill to line
Yes it could be. Bend the rod that holds the ball into the water. This should do it. As far as the fill line. It is not imperative that it fills to the line. In fact it uses more water to do so. This is going to save you water anyway. Adjust your chain that lifts the flapper a little shorter so that it lifts the flapper up higher. This will stop you from having to flush the handle several times. Let me know if this works.
Feb 20, 2013 | Home
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
Fluidmaster Dual Flush Valve S2DBL won't flush.
Fluidmaster S2DBL Dual flush valve - would not flush
The dual flush wouldn't work at all. So I slid the lid off part B (lever mounting base) and found the ball end of flush cable was not in the mating hole on lever arm. With needle nose pliers I pulled and pushed the ball into the hole and slide lid back on till it snapped. Snapped B to C (handle) - problem solved!
RAP
Jan 29, 2012 | Home
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
Tilet want flush no pressure when depressing
Take off the top lid and look at the flush handle mechanism. You'll see a not that holds it onto the tank. Tighten the nut so it is snug. Don't overtighten it or you could crack the tank. Next inspect the chain that goes between the end of the flush handle rod and the flapper valve. It should lift the flapper all the the way up when you operate the handle.
Apr 11, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37 Logo
57 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
