We put the game disc into the ps3 and it makes a weird grinding noise and it wont pop up the game disc icon at all.
Make sure that you do not have the PS3 on it's side. Lay it flat. Insert a MOVIE DVD first and see if it will recognize the disc.
If you continue to hear a grinding sound when the ps3 is laying down that could only mean one thing, you need a replacement drive.
Dont forget to Always update your Playstation to the newest firmware.
SOURCE: I can't put a disk
Have you checked that theres no disc in there 1st?
If so push the disc in slowly.
SOURCE: Weird noise
sounds to me like your fan is on the way out and the bearings are seizing up.
if its in warrently please give sony a ring,
if not browse ebay for a new fan and heat sink and use this link to help you fit it: http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
hope this helps :)
SOURCE: games wont load on my ps3
i have the same problem but if you go to play a game demo then hit the ps button the game is loaded and ready to play
SOURCE: My PS3 won't play an disc games, the disc icon doesn't even show
Sadly there currently is no fix for this problem. I've also had this same problem and contacted Sony about it.
You need to send it in to them to get it serviced. You can do this at:
www.us.playstation.com/Support/PS3
or
uk.playstation.com/help-support/ps3
If your warrenty has expired it will cost around $180.
Hope This Helps. Also be sure to rate whether it did or not.
SOURCE: when i put any disk in my ps3 it wont load and the
Thats a blu ray drive fault you have to get your PS3 fixed or replaced
