Have had the machine for a couple of years without issue. Recently, the machine still makes espresso but if I try to dispense hot water (including for a de-scale) or use the milk jug, the machine just displays the message - heating water then never gets any further, no matter how long I leave it for. Thanks for any suggestions.
SOURCE: Describe your DeLonghi BAR 32 Espresso
many of them having DeLonghi BAR 32 Espresso is suffering from the same problem it cannot be solved it is this model's drawback
SOURCE: EAM3500S will not froth milk ?
First, check to see if it will pump out steam without a ton of water. If it doesn't, don't use it.
Now, skim milk is terrible for it, the bubbles are too dry and
flavorless. Use 2% milk or half-and-half. It should be cold (very
cold). I put mine in the freezer in a steel frothing container for 5-10
minutes before use. Just barely submerge the wand (about .25") and turn
on the pressure. It should sound like tearing paper (not like blowing
bubbles through a straw). Do this until volume increases to around
double (if you have a frothing thermometer, it should be around 100
degrees F). Now submerge the wand farther and tilt the cup to create
swirling (this is called stretching & sweetens the milk). This
should be done until the temperature is around 140-160 degrees F. Done.
If your machine is no good for steam, there's another way: Put milk
into a steel cooking pot (I use a saucier for large groups) and put it
in the freezer. When very cold (ice forming) put on stove. Whisk
briskly while heating up on medium-high. It will create fine foam &
stretch the milk at the same time. The bubbles will start big, but
become finer as time goes by. I test by stocking my finger in &
going until it feels nearly scalding & remove from heat. Just use a
ladle for he milk & a spoon for the foam.
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Here's what I did... with great success:
If you've cleaned all the milk deposits from around the o rings and you still have a problem then its almost certainly the milk spout (the little pipe that directs foamy milk into your cup)
Detatch the spout and get a 2.5 mm drill bit and use it to clean all the milk deposits out of the part that plugs into the lid. Rinse through with water to clean away all the bits of hard milk.
[If you put water through the spout before and after, you will notice a dramatic difference]
Doing this completely fixed the problem for me (I had about 3 years of milk build up in mine!).
Hi. Did you ever get to the bottom of this? I have the same issue, although it will dispense water during a de-scale. I have ordered a couple of replacement TCOs as one had gone, although I think they will just go again.
Any reply will be very helpful
Thanks.
Did you solve it? I have the same problem now
