the amount of flashing lights will give you a Flash code. If the the lights are going up and down, you may have a locked joystick. one method is to turn on and (within 10 sec.) push the horn button twice. Push the power button then push the joystick forward until there is a beep sound then back until you hear a beep sound to unlock.
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
I would think there is a communication error from the joystick to the controller. One time i had this and one of the plug ends was broken off from the joystick cable. Make sure all the plug tips are straight and not missing or broken on the joystick cable and also on the joystick and controller. it could be a simple fix like replacing the cable, but if you have a broken part in the controller or the joystick ports you will have to replace the defective part.
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
follow that joystick cable make sure it hasn't been pinched also i would make sure everything is connected ,you could have dis connected something on accident.
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
The 8 bar flashing lights indicate a possible control system trip. Without a serial Number or knowing which controller system you powerchair has, I will cover the common used controller systems for the model of powerchair you have.
If you have the Pilot or VSI control system the control system detects an internal problem within its self or the joystick, and I've seen it a couple of times when both the controller and joystick have an internal problem.
If you have the Pilot + or VR2 control system the control system detects
an internal problem within its self and/or the joystick and/or a communications error between the joystick and controller. I've seen it once when the controller, joystick and cable between the joystick and controller being deffective. Due to the flashing lights and you have a Pilot + or VR2 there is a good chance the problem is the cable between the joystick and controller.
The possible solutions and repairs above will require the need for an authorized person to perform the tasks. Give the company that sold you the power chair a call, or anyone or different company which works on power mobility products as the part(s) needed will only be sold to authorized deallers or service providers.
Hope this helps, if so, please respond to this solution which will help
others
who may have the same question. Thank you
for using FixYa. Flavadave75
On the front of the usb reciever you will see a green flashing LED. This is actually a button which when pressed will then start to blink more rapidly as it is now searching for the controller. If you then immediately press a button on the controller whilst these rapid flashes persist it will find the controller. Both reciever and controller will now show solid LED lights. Voila job done .....happy gaming:P
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
