SOURCE: la luz en el tablero se enciende cuando esta en
llena de liquido para limpia brisas y ya esta ,este lo puedes localizar a un lado del motor tiene una tapadera amarilla,y la otra esta atras en donde abres la puerta de atras y esta donde esta la luz de atras suerte!!!
SOURCE: a los 10 m. de
If my translation software is correct, I understand that on a cold start one of your cylinders is misfiring, not running properly. If this is correct, since you say you have changed wires and spark plugs, you problem is either in your ignition or your fuel system. Since you didn't mention any misfire problem at high engine speeds, I'm going to say that you probably have a vacuum leak on the misfiring cylinder.
When the engine is cold and you are starting the engine using the enricher, the manifold vacuum is very high. If you have a vacuum leak, it is going to draw in a lot of air under these conditions. I'd replace the seals at the intake manifold and head junctions and the seal that the carburetor plugs into on the manifold. There is also a vacuum hose that supplied vacuum to the VOES switch and the fuel petcock, check to make sure it doesn't have any cracks in the hose.
Buena Suerte
Steve
SOURCE: luz roja intermitente en piloto
La soluci?n no es exactamente para este modelo, pero si tiene el IC 2001 te puede servir.
Conecta a masa las patas 81 y 82 del IC2001 durante unos 15 segundos.
A ver si se te soluciona.
Saludos.
SOURCE: Jeep liberty 2004 se enciende una luz en el lado
Exactamente cual es la luz que ve en su tablero...
Comentenos para poder darle mayires detalles.
SOURCE: Alarma roja en el tablero Red alert on the board
Marca y modelo de su cami?n? (Make and Model of your truck?)
¿Tiene un manual puede leer? (Do you have a manual you can read?)
Algo necesita atenci?n (Something needs attention)
