Download driver and software from the following link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategor%E2%80%8By?cc=us&lc=en&dlc=en&product=3940574
In order to achieve wireless capabilities you need to temporarily connect a USB cord into the computer and printer to find your wireless network through the HP software. If you have a Windows computer and the Solution Center is already installed on your computer, then follow these steps:
1. Go into Devices and printer
2. Right click on the printer, select remove device
3. Click on your Start Menu, then All Programs
4. Click on the HP folder
5. Click on your printer, then printer set up and software
6. Click on add a new printer, click on wireless (This is where you can temporarily connect your USB cord)
SOURCE: Can't print using HP C6180 Printer via DG834G router
I helped a friend with this problem. He had Vista and was running through a Linksys router. You could see the printer, access the webserver through Internet Explorer by browsing to the IP (192.168.1.X), but the print job would hang, but would kick off immediateley if you reboot, but after it came up and printed that one job, it wouldn't print again. Here is the fix:
Find the IP of the printer and the exact name, which you should be able to get from browsing in Internet explorer to the IP. I think its under the farthest left tab and the 2nd option on the sidebar. I renamed it to HPC6180 because the original name was something like HP92601345U.
Now right click on the start button and click properties and select Classic Start Menu and click Apply/OK. (You can change this back later)
Click on the start button again and click Run and type in "drivers". When that folder opens up, go into the "etc" folder.
Right click on the file named "hosts" and click properties and uncheck "Read Only"
Then double click on the "hosts" file and open it in notepad.
Go down to the first line that isn't commented, it should say something like 127.0.0.1. Position your cursor on that line and hit enter to move 127.0.0.1 down one row. Then enter the IP address of your printer. Space over and line up with the entry below and add the Host Name (mine was HPC6180).
Click file and Save As, and in the file type, change it from .txt to "All files" and click ok, and click OK to overwrite existing file.
Close all your windows and reboot and try to print again. It should work now.
SOURCE: Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
SOURCE: WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
SOURCE: Temporarily Disable MAC address
Open the Router page using the following steps:
1. Open the browser (Internet Explorer or Netscape).
2. Access the Router (usually "http://192.168.1.1";
or "www.routerlogin.net" or "www.routerlogin.com").
3. LOGIN TO THE ROUTER (User Name = 'admin', Password = 'password';
unless you have changed it).
and then click on advanced wireless settings...
Click on setup access list..
Uncheck "TURN ACCESS CONTROL ON"
This is the process to disable MAC filtering..
In case u need further help u can contact me..
SOURCE: Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
This could be a firewall issue. Make sure to allow full
access to all Lexmark software and printer communication processes in the
program rules/permissions for your firewall.
Also, place your printer where it receives excellent wireless
signal quality and away from other electronic devices which can cause wireless
interferences (e.g. cordless phones, microwave ovens, baby monitors, garage
door openers, and other wireless electronics).
