Nautica N07574 Wrist Watch Logo
A
Anonymous Posted on Dec 23, 2013
Replace watch battery - Nautica N07574 Wrist Watch
2answers
What battery fit Akribos XXIV AK 522 BK
the Akribos XXIV AK 522 BK watch requires a standard watch battery. You can replace the battery by visiting a local watch repair shop or by following the instructions . If you prefer to have the battery replaced by mail, you can check out RepairTJC.com which offers quality Akribos XXIV watch battery replacements starting at $14.99 per battery. They also provide a free shipping label.
1helpful
Why did hands come off during watch battery replacement?
If the hands of your watch have come off after replacing the battery, it could be due to a few different issues. Here are some possible causes and solutions:
  1. Improper installation: If the hands were not properly aligned when the battery was replaced, it could cause them to come off when the watch is turned face-up. Make sure that the hands are properly aligned and securely fastened to the watch movement before reassembling the watch.
  2. Loose or damaged hands: If the hands were loose or damaged before the battery replacement, they may have come off when the watch was turned face-up. Check the hands for any damage or wear and if necessary, replace them with new hands.
  3. Damaged watch movement: If the watch movement was damaged during the battery replacement process, it could cause the hands to come off when the watch is turned face-up. Have the watch movement inspected by a professional watch repair technician.
  4. Incorrect battery size: If the incorrect battery size was used to replace the old battery, it could cause the hands to come off when the watch is turned face-up. Make sure you are using the correct battery size and type for your watch.
  5. Incorrectly set the hands: During the battery replacement, if the hands were moved or set incorrectly, it could cause them to come off when the watch is turned face-up. Double check that the hands are set to the correct time and position.
Oct 31, 2022 • The Watches
1helpful
I have a sweda watch with no battery. The only identification is that the front says "Lifeline". Can you "best guess" at a compatible battery?
I can't find much on the watch. Sweda is one company, and Lifeline is another.
https://www.google.com/search?q=Sweda+Lifeline+watch
Look inside the watch and look for an engraved number near the battery socket. If nothing there, a local jeweler will have a battery that fits the space. Voltage is 1.55 volts, silver oxide are best.
Watch Battery Size Chart - 377 Watch Battery Replacement
Ad·https://www.microbattery.com/watchbatteries
For batteries at low prices, shop Microbattery for high quality watch battery replacements. Watch batteries from the top manufacturers like Murata, Renata, Energizer, and Seizeken.
‎Changing Watch Batteries · ‎364 Watch Batteries · ‎Closeout · ‎Browse All Watch Straps
Oct 14, 2022 • The Watches
GB5. How can I replace batteries?
All watch batteries can be replaced, even gold watches.
BIG Battery!
https://www.google.com/search?q=GB5+replace+battery
The problems of not having full 'make model (what it is)'.
Jun 13, 2019 • The Watches
1helpful
VX82 X530 Battery for Pulsar watch
The VX82 X530 battery is a replacement battery for the Pulsar watch. It is a lithium-ion battery with a capacity of 3.7V and 530mAh. It is important to note that you should only use a battery that is specifically designed for your Pulsar watch, as using the wrong type of battery can damage the watch or be potentially dangerous. Always use caution when changing a watch battery.
Yyou can try searching for "VX82 X530 replacement battery" or "Pulsar watch battery replacement" on online retailers such as Amazon, eBay, or Alibaba. You may also check with the manufacturer of your Pulsar watch or a local watch repair shop for replacement options.
Replace battery rosendahl watch 43250
To replace the battery in a Rosendahl watch with the model number 43250, you will need to follow these steps:
  1. Remove the back of the watch by using a watch back removal tool or a small flathead screwdriver to gently pry it off.
  2. Take out the old battery and discard it properly.
  3. Take the new battery and orient it so that the positive side is facing up.
  4. Place the new battery in the watch, making sure that it is positioned correctly and securely.
  5. Replace the back of the watch by pressing it back into place. Make sure that it is securely fastened.
It is important to handle the battery with care, as they can be damaged if they are dropped or handled roughly. If you are uncertain about replacing the battery yourself, you can have it done by a professional watch repair technician. They will be able to replace the battery safely and ensure that the watch is in good working order
Battery replacement
If you have a warrantee with your watch you may have to return thew watch to the manufacturerer for battery replacement. Othet than that, most any jeweler can replace the battery. Mike D 75
3helpful
3answers
Replacement battery for Skagen 430SSXD watch
send your watch into skagen since you have a lifetime warranty you do not want to breech that. plus they reseal your watch and other watch repair places cant.
http://www.skagen.com/service/home.fx
2answers
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Top Nautica Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Nautica Watch Expert? Answer questions, earn points and help others
