Mustek PVR-H230 MP3 Player Logo
Posted on May 17, 2009
Time how do you set the time and date
John Elliott
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 31, 2010
John Elliott
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
472
Points
Go to set up menu ok
display date:time disp
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
3453
Points
41
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
1helpful
I cannot reset time and date on my samsung z2
Want to set the date and time for your mobile phone? Follow these easy instructions.
From a Home screen, tap the Arrow icon to display all apps.
  1. Navigate: Settings > Date & time.
  2. To use network-provided values, turn on the following:
    • Automatic date & time
    • Automatic time zone
  3. When manually setting data & time, perform the following:
    Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
    1. Tap Set date.
    2. Adjust the date then tap OK.
    3. Tap Set time.
    4. Adjust the time then tap OK.
    5. Tap Select time zone then select a time zone.
  4. If desired, tap Use 24-hour format to turn on or off .
How do i set the time on a pantech p5000?
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauder™ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Setting time, date on power book g4
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
7helpful
How do you clear memory, and set date and time 712c
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
45helpful
2answers
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
127helpful
4answers
Current time and date samsung tocco lite
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
1helpful
How do i set the time on my nokia 2630
Select Menu > Settings > Date and time. Select Date and time settings to set the date and time. Select Date and time format settings to set the formats for date and time. Select Auto-update of date & time (network service) to set the phone to update the time and date automatically according to the current time zone. Hope it helped...
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 • Cell Phones
31helpful
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Top Mustek Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
Music Lounge
Music Lounge
Level 1 Expert
Rick
Rick
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
