My coolpix s6300 says that my memory card contains no image data but i put it in my computer and i can see all the pictures so the camera just cant read it help?
SOURCE: Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
SOURCE: I have taken several pictures with my new camera -
Make sure you have no pictures on the internal memory of the camera. If you do, format the internal memory with no card in the camera. Then, download any pics you can save from the card to your computer. Then, go into the menu and find "format"...follow the on-screen instructions to erase and optimize the card for the camera.
SOURCE: my Nikon Coolpix S8000 will no longer read the
Sounds like you've added images to the card using the computer or another camera. The Nikon doesn't recognize them and concludes the card is empty.
SOURCE: Nikon s220 says file contains no image data when I
When you remove your card from the computer, do you remember to use the "safely remove hardware" function? If not, you risk corrupting the card which is what probably happened.
SOURCE: How to recover a file contains no image data?
Recuva (pronounced"recover") is a freeware Windows utility to restore files that havebeen accidentally deleted from your computer. This includes files emptied fromthe Recycle bin as well as images and other files that have been deleted byuser error from digital camera memory cards or MP3 players. It will even bringback files that have been deleted from your iPod, or by bugs, crashes andviruses!
Go to these WEB sites to down Recuvahttp://download.cnet.com/Recuva/3000-2242_4-10753287.htmlwww.filehippo.com/download_recuva
